NEED HELP! Push button toggle circuit
Discussion in 'The Projects Forum' started by LTD566, Aug 29, 2011.
  1. LTD566
    Aug 29, 2011
    6
    Hello!
    I am new to the forum and I have been trying to put together a circuit for the past couple days with no luck and have just about gone crazy...
    I need to be able to control 3 individual LEDs with one push button.
    For example, I push the button once, LED 1 comes on. I push the button again LED 1 goes off and LED 2 goes on. I push the button again, LED 2 goes off and LED 3 goes on. I push the button again, LED 3 goes off. I push the button again and the cycle starts back at LED 1...
    I am not 100% electronic literate, although I have taken basic electronic courses, so for the most part I can understand and intemperate circuit diagrams.
    I wish to keep the circuit as basic as possible, with most of the components being available at radio shack, or online.
    PLEASE, ANY help would be appreciated! Even if someone knows of a similar circuit that I could start off with looking at would be great.
    Thanks!
  2. Kermit2
    Feb 5, 2010
    3,852
    968
  3. LTD566
    Aug 29, 2011
    6
  4. LTD566
    Aug 29, 2011
    6
  5. praondevou
    Jul 9, 2011
    2,936
    489
    No, only the counter. However, it doesn't have much output current, if you want brighter LEDs you need to add a driver for each LED.
  6. LTD566
    Aug 29, 2011
    6
    ok great, thank you!
  7. chejian6
    May 22, 2011
    10
    I will use a 8 pin microcontroller with build-in oscillator. ATtiny, PIC, or STC15F02. the circuit is simpler than a cd 4017, but needs simple program
  8. LTD566
    Aug 29, 2011
    6
    What exactly is required to program a microcontroller?
  9. JingleJoe
    Member
    Jul 23, 2011
    185
    10
    I'd forget the microcontroller and go with that 4017 circuit, less stuff required in the long run.
    Additionally, using a button as the clock via a transistor is a fantastic idea, inspirational, my mind is alive with new ideas for circuits now!
  10. LTD566
    Aug 29, 2011
    6
    Agreed!
    Ordered components online today, so hopefully by Friday I will have a working functional circuit.
