Hi. I need help writing code for a 12F675 to flash LEDs in a specific sequence.
I want to press a switch, display the following binary sequence, then pause until the switch is pressed again: 1000,0100,0010,0001,1111,1000,0100,0010,1111,1000,0100,1111,1000,1111
Seems simple enough, but I've been unsuccessful in my lame attempts at coding. I can design & build the circuit easily, just need the asm code.
This is for a custom T-shirt using 4 LED backlight assemblies from ipod screens. Thanks very much!
