Need help on thermoelectricity project
Discussion in 'The Projects Forum' started by jocags, Aug 10, 2006.
  1. jocags
    Aug 10, 2006
    Hi all! I've read about thermoelectricity recently and got interested on it. I learned that the Russians use this to power radios in the 1920s. Does any one knows or willing to share some simple thermoelectricity projects which i can start with? Thanks in advance.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I've seen a photo of one of those Russian radio power devices. It was a ring that sat on the shoulder of the globe on a kerosene lamp. It looks like several hundred, if not thousand thermocouple joints are present.
    Modern designs use a hot isotope as a heat source, but the may use Perlier junctions as the voltage generator.
    Omega Corp. sells thermocouple wire in bulk. You'll need a few hundred feet to make all the twisted junctions that will give you a couple of volts at any current. You will certainly get experience stripping wire.
