NEED HELP ON SHIFT REGISTERS
Discussion in 'Homework Help' started by computerwebmaster, May 20, 2009.
  1. computerwebmaster
    May 20, 2009
    PLS THIS IS AN ASSIGNMENT. PLEASE I NEED HELP ON HOW TO GO ABOUT IT
    Design & Construct a 4bit serial-in-parallel-out shift register
    Hint:
    [1]Construct a 1Hz clock sienal using 555 timer
    [2]Construct a shift register with logic selection provision
    [3]Construct a read output line with a read selector
    [4]All output should be monitored with LEDs
    [5]Power from a 9volt battery
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Our site will provide advice and help, but we aren't here to do your work for you.
    Have you been able to do any of the assignment?
  3. Bernard
    Aug 7, 2008
    4,235
    414
    Did you look in AAC library Vol IV Digital, or see the white box to right of CIRCUITS type in shift register.
