Need help on making a 13.5v limiter
Discussion in 'The Projects Forum' started by Electro4321, Jul 8, 2011.
  1. Electro4321
    Jan 6, 2011
    Hey everyone,
    I've been looking everywhere for a 13.5v limiter because im charging supercaps via a solar regulator and the cut off voltage is at 14v, but i need something that when the caps reach 13.5v they will stop charging and once the voltage drops the caps can charge again.
  2. iONic
    Nov 16, 2007
    1,422
    68
    One option is a Zener Diode.
  3. shortbus
    Sep 30, 2009
    4,098
    1,697
  4. CDRIVE
    Jul 1, 2008
    2,223
    99
    A diode in series will drop ~ .7V.
  5. iONic
    Nov 16, 2007
    1,422
    68
    His Supercaps are rated at 14V max and he want's to stay just under that (13.5V), but the solar panel will output as much as 20V even though they may be rated at 12V. I've seen more that 19V on my panel.
  6. CDRIVE
    Jul 1, 2008
    2,223
    99
    This statement led me to believe that he already had a 14V reg but needed to drop an additional .5V.
