Need help on information please!
Discussion in 'The Projects Forum' started by Ryka Thomas, Feb 7, 2016.
  1. Ryka Thomas
    Dec 16, 2015
    32
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    Your question is unclear. That device can accept higher input voltages and will put 5V on the USB power pins. It can handle a load up to 3A. The load presented by your phone will be determined by the phone itself.
    spinnaker likes this.
  3. Ryka Thomas
    Dec 16, 2015
    32
    OK so this is my question let's forget about the device. So is the usb port that outputs 5v at 3a step up it must be
  4. spinnaker
    Oct 29, 2009
    5,085
    1,181
    You cannot step up current without stepping down voltage.
  5. crutschow
    Mar 14, 2008
    13,503
    3,376
    Get more power out then you put in, that you can not do.
