Need help on h-bridge gate driver!!!!!!
circuitnoob89
Joined Feb 8, 2014
5
Hi all,
May i know what is the purpose of the capacitor and the zener diodes is used for when connecting the driver to the H-bridge? And i know i need a resistor to make sure the transistor stay off when it is suppose to. but how does that works?
Below is the attachment of my circuit diagram.
inwo
Joined Nov 7, 2013
2,419
I don't see any Zeners. And specifically which capacitors?
I see that this has been posted before and others see them.:confused:
Also where is the low side bridge connection.
Maybe some things are assumed when more experienced than I.
circuitnoob89
Joined Feb 8, 2014
5
Hi guys,
Sorry for the lousy information i provide, and reason for repeated post is because i thought that post is being neglected. hahaz...
The zener diode supposed to be connected in parallel with SRC_HS1 and GATE_HS1, as well as SRC_HS2 and Gate_HS2.
