hi guys i need some help here, i dont know how to use transistors but i need to know how can i make a common emitter amp to energize a 6v relay via pic16f84a's voltage output
5A !? That seems like a lot. It it's real (check again, I doubt it), be sure your power supply can handle that. Maybe the 5A is for the switching capability of the relay, not what it draws?5a and i tested that i can use 5v to energize the 6v relay
by Jake Hertz
by Duane Benson
by Robert Keim
by Jake Hertz
