Need help on driving relay with PWM output
Discussion in 'The Projects Forum' started by StupidPig, Jul 28, 2009.
  1. StupidPig
    Jun 5, 2009
    12
    Here is the background....
    My car using the Hi-beam as both Hi-beam and DRL, I would like to make the DRL function to a seperate LED circuit, So the Hi-beam bulb is only on when Hi-beam is switched on, and a set of LED will be on for DRL.
    I used a DMM to measure the voltage on the Hi-beam wires, and it gave me reading of about 12v when Hi-beam is on, and 7.6v when DRL on. So I was thought I can use a SPDT relay with 8v pull-in voltage to seperate the circuit for Hi-beam and DRL, then use another SPST relay with 6v pull-in voltage to switch on a 12v with the 7.6v output to drive the LED set.
    Looks good when Hi-beam is on, but the when DRL on, the LED is not turned on, and I hear some buzzing sound come from the relay. I guess the 7.6v for DRL may be actually achieved with PWM and thats why the relay didn't switch to on. So, is there any solution for this? Will adding a capacitor like the following works?
  2. StupidPig
    Jun 5, 2009
    12
    Bump.... Nothing can be done? Or too simple for not worth for an answer?
