Need help on DC Biasing
Discussion in 'Homework Help' started by BlackMelon, Jun 6, 2016.
  1. BlackMelon
    Mar 19, 2015
    33
    The problem statement is on the file "Bias Ask". After I've seen this, I quickly draw a small signal model of the whole circuit in the file "small signal ask", which allows me to consider this amplifier as "Series-Shunt" or "voltage to voltage" amplifier.
    The problem is not with the small signal circuit but the DC biasing. I need to know the DC collector current(IC) first so I can determine the "early resistance, ro". I set the vs=0V... And so what's next? How can I determine the IC since the 200uA is not emitter current? Can we consider the op-amp as an ideal one (V+ = V-) in DC biasing?
    Thank you
    BlackMelon
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Simply assume that Ic is 200μA.
