Need help on clarify on IC..
Discussion in 'The Projects Forum' started by woon_h88, Sep 14, 2009.
  1. woon_h88
    Thread Starter Active Member
    Mar 25, 2009
    46
    I wish to clarify on 75LBC184...Is this IC used on RS485 interface? As im trying to identify a TERN board which IC is being used on RS485 interface..When i try to check which IC its using by multimeter, only 75LBC184 respond..But i search for the datasheet, it didnt show anything on data transmission..So i wish to know am i correct before replacing the IC from the board..
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Here is the datasheet of the 75LBC184.
    Greetings,
    Bertus
