need help on bjt amp circuit
bhan19920
Joined Nov 8, 2012
5
hi,
i built this amplifier circuit but i do not know how to simulate it in multisim. Can anyone show me how to simulate this circuit in multisim?
my requirement for this circuit is stage voltage of -100. If this circuit is not showing the gain of -100. what components should i change?
sorry for my bad english but i hope you understand and thanks in advance.
p/s: attached is the my circuit in multisim.
Audioguru
Joined Dec 20, 2007
11,248
I tried to unzip the file but its MS11 file type is not a valid one.
I agree than a schematic should be attached as a normal PNG file type.
34,408
from my calculations, i assume it is correct.
should I use standard values closes those i have in this circuit?
That's the usual procedure since you can't readily buy arbitrary value components.
Also, a gain of 100 is rather high for a single stage. Suggest you break it into two stages. That way each stage only needs a gain of 10.
