Need help on artificial Pancreas
Discussion in 'The Projects Forum' started by khadeejabaqui, Jan 25, 2016.
  1. khadeejabaqui
    Jan 25, 2016
    9
  2. #12
    Nov 30, 2010
    16,671
    7,314
    How much of one solution neutralizes some amount of another solution is about the concentration of each solution. This is not an error, it is a fact. This fact can not be, "fixed" electronically. It's a Chemistry problem, not an electronics problem.
  3. Marcus2012
    Member
    Feb 22, 2015
    349
    26
    the acid base reaction is 1:1
    NaHCO3 + CH3COOH → CH3COONa + H2O + CO2
    While you have complete control over the molarity of your Sodium Bicarbonate solution Vinegar traditionally has varying concentrations of acetic acid. This may be the reason some base is remaining.
  4. wayneh
    Sep 9, 2010
    12,379
    3,232
    Calculate the molarity of each solution. The answer will become obvious.
