need help on an eye blinking for sculpture
Discussion in 'The Projects Forum' started by 2200, Oct 13, 2009.
  1. 2200
    Oct 13, 2009
    I am making a large outdoor sculpture. It has an image if a buck with a diamond eye that I would like to have blink when the viewer picks up a plastic gun (used in big buck hunter arcade games) and shoots it. The mechanical portion will be a steel half dome that pivots, and closes over the eye and back. I am trying to figure out if maybe the gun shoots a LED light goes to a sensor which then is attached to a selanoid, and to a switch or motor to make the half dome shaped lid shut and open quickly .. obviously I don't know what I'm talking about if you know of a better way, can you please help? It is outside and I want it to work when its bright and sunny out too. maybe like a garage opener? There must be a way. And how does power play into this?
  2. Bernard
    Aug 7, 2008
    4,233
    414
    Maybe the gun could fire an ultrasonec sound burst that the buck could receive in his ear , amplified, detected,amplified ,finally triggering a solenoid to blink eye. How heavy is eyelid,& how large? Use rechargeable batteries [ 4 Ni-MH AA cells ] and solar charger. What is the firieing distance. What country?
