Need help on Amplitude Shift keying
Discussion in 'Homework Help' started by victorment, Feb 25, 2011.
  1. victorment
    Jul 4, 2010
    52
    I have a project at school. The professor requires as to make a circuit that outputs Amplitude shift keying. If I input 1101. the output amplitude should be shifted varying on the input. can someone please help with this project. thanks in advance
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  3. victorment
    Jul 4, 2010
    52
    thanks man. But I have no idea on how to make a circuit of ask. Can you help me?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    What did you mean by "If I input 1101"?
    Do you mean that the output voltage must be controllable by a 4 bit code?
  5. victorment
    Jul 4, 2010
    52
    Yes. It is controllable by a 4 bit code. Can you help me? Ive tried to add the square wave carrier and the frequency sine wave. But the output is inverted. If logic 1 is present the output wave form would be low and when logic 0 is present the output would be high. Is this correct? Can you help me with this?
  6. Ron H
    Apr 14, 2005
    7,050
    657
    A four bit code can yield 2^4=16 different output levels. You had better find out if this is what is required.
  7. victorment
    Jul 4, 2010
    52
    Yes that is the required. If I input 1011 the anmplitude should be 1011. Can you help me with this?
