i have an ac motor with a voltage rating of 200 volts. I don't have any 200 volt power source, would it run on a 220 volt power source?
It depends on what you think the 200 volts refers to. If 200 Volts AC is a peak rating then I would hesitate to connect it to a source of 220 VAC - RMS since the peak voltage will be about 312 VAC PEAK. If the rating is an RMS rating you might get away with using it on a 220 source, but it might get hot and have a shorter lifespan.Originally posted by guitaricci@Apr 28 2006, 10:11 AM
[post=16654]Quoted post[/post]
Thread starter | Similar threads | Forum | Replies | Date |
R | Need help! Stepper motors | General Electronics Chat | 8 | |
R | Need help! Stepper motors | Microcontrollers | 13 | |
I need help to test 2 motors | General Electronics Chat | 103 | ||
K | I need help with this DC motor | Power Electronics | 1 | |
D | Need help with a project involving two R/C grade BLDC motors | Power Electronics | 2 |
by Duane Benson
by Aaron Carman
by Aaron Carman
by Aaron Carman
