Why per ligt? Are they used for turn signals? Won't hurt, though, to have one per light and that will lessen the wattage carried per relay.ok, so on my shopping list, I need (per light):-
Depends on the DC rating at 12V. Need to know the wattage of your bulbs. Those values sound about right. Some generic automotive relays are quite cheap ~$5 to 7 USD.1x 12v Relay - does it matter what wattage they are as I have a 30W and 40W?
Yes.1x NE555N Timer
No. Those are ordinary diodes, like 1N4001 or 1N4002.2x 12v 5W Zener Diodes
In this circuit, you do not need such high wattage. 1/4 watt will do. If Maplins is like the old Radio Shack, I would just get its assortment of 1/4 watt resistors.1x 2W Res 100K resistor
1x 2W Res 220K resistor
You do not need (or want) electrolytic capacitors in this circuit. Use regular polyester (Mylar) or ceramic . They will come in voltage ratings of 35V or more, which will be OK. Go for physical size, cost, and availability. Voltage rating, as long as it is high enough, doesn't matter.As for the capacitors......this is where I am unsure to their values as never used these before.......when I have looked at Maplin, they don't seem to do 12v versions - is this right?
