need help...nt difficult, but i dun know...
Discussion in 'Homework Help' started by polarbearbear, Apr 1, 2009.
  1. polarbearbear
    Mar 12, 2009
    http://i681.photobucket.com/albums/v...ledcircuit.jpg
    erm..anyone can teach me how to define d condition of d push on switch using CCS code. i wan the function: when push button 1 is pressed, LED 1 will on and LED 2 keep off. Then push on button 2 is pressed, LED 2 will on then LED 1 will turn off. And exclude d condition both push on buttons are pressed together.
    really thx alot.....
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Sounds like an SR Flip Flop, a uC is a bit of overkill.
    Read the Wiki Article An SR Flip Flop and maybe a NAND Gate or two should do what you are trying to from how I'm understanding the application. Either way, seeing how the flip flop works should give you a very good start on the code if you must use a uC.
    The schematic is about 4x too small to read.
