You already made that clear. I'm working on it. It's called a lock-out or a latch-out. That kind of circuit will only keep the circuit from sending a second pulse until you disconnect the power. After you disconnect the power, the circuit can't send a second pulse because it doesn't have any power.I suppose I should clarify what I meant then.
I'm not concerned with what happens after disconnect. I am concerned with the output attempting to send a signal to the lock actuator every time the sensor crosses the 5v threshold.
No, I don't know; will need to look at the datasheet.I think this is about it, give or take some values.
I was asking if you personally know that grounding the strobe will force an open collector.
Oh...you think so. I guess we'll have to try this if we can get the right SCR.
How's the build coming?I feel so helpless at this point...lol you guys are awesome!
