Need help making a summing amp
dumle29
Joined Jun 26, 2011
45
okay so i need to make a little box that can mix a mic signal with a line-in signal, and throw it out to a headset.
So i have looked asked around and have come this far:
  • This mic
  • Two summing amplifiers (stereo)
  • (Possibly some buffing amps)
  • And then two pot´s, proberbly 10k as voltage divider volume controlls.
now im having a hard time figureing out these things:
  • Should i add a pot for gain?
  • What resistor´s should i use?
  • would a 5v supply work (USB)?
  • Can i use two L165 op-amps?
R!f@@
Joined Apr 2, 2009
9,918
1. What is the impedance & power of the headset?
2. What is ur power source?
3. Or what kind of power is feasible for the application, meaning is USB 5V easier for you or to use a separate adapter ?
{ed}
Ur mic needs more than 5V, so I presume a separate adapter is in order
SgtWookie
Joined Jul 17, 2007
22,230
You could use an ICL7660 or 7660S or similar capacitive boost IC powered from a USB port to supply your mic. They are good for 10mA current.
As far as mixing/volume control, you could feed the end of 10k audio taper pots, take the signal level from the wiper, feed it through buffer amps, then mix the two using 10k or 20k resistors, and feed that output to a 2:1 gain opamp. Not very complicated.
If you really needed adjustable output gain, I suppose you could add a pot in the 2:1 feedback path.
dumle29
Joined Jun 26, 2011
45
okay, so thanks for the lightning quick responses, just saw that with the mic too :/ guess im going for external supply.
i have no idea of how to find the impedience of my headset, though messured with an ohm meter the resistance is 36Ω
soo, if im fine to leave gain alone (no pot) ill go for that :)
i have a hard time finding a stereo log pot around, couldnt i use a lin?
dumle29
Joined Jun 26, 2011
45
hmm okay now im confused? i have no experince in audio stuff. I was told that i should use a op-amp (summing)
the resistance is as before said, 36 ohm messure with an ohm meter
its a sony xb700 headset
yourownfree
Joined Jul 16, 2008
99
an LM386 is powerful enough to drive the headphones and be all you need. All you do is sum the input to the op amp, the LM386. The output is mono of course so tie the left and right headphone line together and connect to the output of the op amp. The op amp amp has a gain of 200 if you need that much. The diagram that comes with the op amp or data sheet on the device is all you need for the diagram. here is the url for the data sheet. http://www.national.com/profile/snip.cgi/openDS=LM386
here is an op am mixer. you could use this circuit and add the lm386 to boost the power or just put the lm386 in place of U1 and call it good. http://www.aaroncake.net/circuits/mixer2.asp
dumle29
Joined Jun 26, 2011
45
what about the cmoy? looks really simple, now just for the summing amp. what about a LM 358 dual channel op-amp?
an mono is a no go, ill tell you why.
im going to a LAN 20 days from now or so, and when i play one my ps3, i have no volume controll and cant hear whats going on around me, so im gonna need this box for both.
i will need stereo since im gonna use it for gaming :)
Adjuster
Joined Dec 26, 2010
2,148
If you want to make circuits without lots of mistakes, you need to learn to draw them less confusingly - the effort will be well worthwhile in the end.
Your circuit appears to be meant to have unity gain both for the microphone and for the line. I would doubt that this is nearly enough, especially for the microphone unless this has a very substantial internal amplifier. Note also that there is no provision for power to the mic.
dumle29
Joined Jun 26, 2011
45
okay, the mic has a built in amp. it uses a 6-12 volt supply, plugged into a barrel connetor, (forgot that)
so i made a block diagram thing
dumle29
Joined Jun 26, 2011
45
thanks, i think ill go for that as the amp after the summing´s.
just a question more. how would i go about making the summings? i have the basic layout figured out. Im however not sure how to connect the mic out to both summings. Is it okay to connect it like this:
line in L---Resistor------------ summing
mic ------Resistor---
line in R---Resistor------------ summing
wouldnt there be a problem with connecting the two summing´s?
