Need Help Looking For Simple LED Flasher
Discussion in 'The Projects Forum' started by george0039, Oct 15, 2008.
  1. george0039
    Thread Starter Senior Member
    Oct 15, 2008
    127
    5
    My name is George, new member here. I am looking for a LED Flasher circuit,non PIC, don`t have access to program them or understand the codes etc. So standard electronic parts would be preferred.
    I would like to have 5 LED`s with 3 on and Two off then have that alternate and be able to adjust the flash rate with a variable resistor. The LED`s would be either Bright White, Red OR Blue if Possible and run on a battery source of 6v to 12v max.
    I would like to install them into a remote controll police boat and have them act as the Flash Bar on the Roof. So the simplier the better.
    If anyone has a Working Circuit they wish to share please let me know. As for buying pre made, Yes available from overseas BUT I like to build my own as much as possible.
    Thanks for your time and help.
    George
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. george0039
    Oct 15, 2008
    127
    5
    Thanks mik3 but from your link it does not say if the circuit can handle a Total of 5 LED`s with 3 on and 2 off and then alternating that, with a power supply voltage of 6v to 12v.
  4. boff1
    Member
    Oct 15, 2008
    26
    Hi there,
    Much cheaper and simpler with a PIC. Suggest you give it a try, you may get hooked!
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See the attached.
    The 4093 is a CMOS quad Schmitt-trigger NAND gate; a very useful device. Typical manufacturer's part numbers are CD4093B or MC14093B, with additional letters/numbers on the end.
    Note that power connections and pin numbers are not shown for the 4093, nor is the 0.1uF bypass capacitor across the Vdd and ground/Vss pins. You can determine these by looking at a datasheet.
    You could substitute TIP120 transistors for the Darlingtons I've proposed, but those I've specified are in a TO-92 case, so they are quite small.
    The 330 Ohm resistors are calculated for blue LEDs with a 25mA current @ 3.8Vf for a 12v battery. You'll have to recalculate the resistors if your LEDs have a different rating.
    R >= (BatteryVoltage - VfLED) / Desired Current
  6. karthik_dm
    Member
    Oct 16, 2008
    27
    [quote=george0039@hotmail.com;92784]Hello,
    George[/quote]
    here u can download the led flasher schematics...
    Code ( (Unknown Language)):
    1. http://forum.allaboutcircuits.com/showpost.php?p=93117&postcount=1
