Need help in Voltage to frequency converter...
Discussion in 'General Electronics Chat' started by silverscorpion, Jul 10, 2008.
  1. silverscorpion
    Dec 5, 2007
    Hi all,
    I need some help in voltage to frequency converter. ie, the input to the system is a varying voltage between 0 to 10 volts and the there should be a corresponding variation in the frequency of the output waveform.
    Can anyone briefly explain the priciple of this converter? Also it'd help a lot if you provide a schematic of the same...
    Thanx.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Get the data sheet of an LM2907. It's a handy IC, as it works both ways - F to V and V to F.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    How do you make a V to F with LM2907?
    Silverscorpion, I'm assuming you did a search. I find it hard to believe the information you want is not readily available.
    EDIT: The LM331 datasheet includes the theory of how it works.
  4. Audiofilo
    Member
    Jul 15, 2008
    13
    Hi, I would recomend IC 4518. Years ago, I made a frequency-voltage converters (for my tester) it work fine, also can make voltage/frequency.
    regards
    audiofilo
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The only 4518 I can find is a dual BCD counter, which isn't even close to what the OP wants. Do you have a more specific IC number?
  6. Audiofilo
    Member
    Jul 15, 2008
    13
    Sorry, I must say XR 4151.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
