need help in this circuit - Zero Bias Schottky Detector
Discussion in 'The Projects Forum' started by harikanaidu, Feb 17, 2016.
  1. harikanaidu
    Nov 28, 2014
    76
    Can any one explain how this circuit detects RF signals
  2. harikanaidu
    Nov 28, 2014
    76
    what is exactly the fuction of this circuit?
  3. Kermit2
    Feb 5, 2010
    3,845
    963
    Looks like it detects by diode rectification of the RF waveform
    Google that term...it is mainly for AM modulation.
  4. Dodgydave
    Jun 22, 2012
    5,141
    767
    Its an AM detection circuit, the diode is a half wave rectifier and the RC filter removes the carrier, so the result is the original modulation audio.
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    The word "detect" used here does not mean what you think. It is not determining the presence or absence of a signal. In radio, a detector is a circuit that extracts the modulated signal (audio, video, whatever) from the carrier wave. The schematic shows a basic AM (amplitude modulation) detector.
    ak
  6. harikanaidu
    Nov 28, 2014
    76
    May i know how this circuit is detecting the mobiles then?
  7. crutschow
    Mar 14, 2008
    13,475
    3,361
    My company used a similar circuit to detect the level of microwave radiometer signals on an earth orbit weather satellite except it used back (tunnel) diodes, instead of Schottkys, for better sensitivity.
    Basically it generated a slowly varying DC level ( a few hundred Hz) in proportion to the intensity of the black body radiation in the microwave spectrum from earth.
  8. harikanaidu
    Nov 28, 2014
    76
    How it is used to detect the mobile signals
  9. Ramussons
    May 3, 2013
    561
    92
    If there's a RF input, you will get a DC output.
    If you have a good tuned filter at the input, you can detect a transmission over a particular radio spectrum.
    Else, you can get DC even from random RF signals, like a motorbike passing by .....
  10. DickCappels
    Aug 21, 2008
    2,753
    665
  11. alfacliff
    Dec 13, 2013
    2,449
    428
    actually, schotkey diodes have a higher minimum rf voltage for detecion than the older germanium diodes. if you apply a little bias to them, they will detect down to almost zero volts.
