Need help in solar tracker circuit
Discussion in 'Homework Help' started by royzerx, Jun 24, 2010.
  1. royzerx
    Jun 24, 2010
    I have to come up with the schematic for a simple dual-axis solar tracker.
    With simple components such as MOSFETs, BJTs, capacitors, LDRs and maybe LEDs.
    Anyone can help?
  2. retched
    Dec 5, 2009
    5,201
    313
    I can help you help you. ;)
    Instructables has many. I have made a few I found on google while working on a version I was designing...which failed horribly. ;) (Dont use a water transfer solution as ballast)
    google 'solar panel sun tracker'
  3. royzerx
    Jun 24, 2010
    here's the schematics for the single-axis solar tracker. I'm having some trouble turning them into dual-axis solar tracker ? Is there any way to modify the circuit?? thanks..:)
  4. retched
    Dec 5, 2009
    5,201
    313
    Its easier that you think. You just make 2 of them.
  5. royzerx
    Jun 24, 2010
    Thank you so much for your help! :)
