Need Help in remaking this project
Discussion in 'Homework Help' started by regal006, Sep 14, 2012.
  1. regal006
    Jul 14, 2012
    20
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    There are a lot of similar school projects in the Homework Help section. I suggest you search and take a look, and then come back with your questions.
  3. regal006
    Jul 14, 2012
    20
    how do i the circuit knows if the elevator is on what floor?
  4. Whyregister
    Sep 12, 2012
    20
    Do you mean how does the circuit know what floor the elevator is on?
  5. regal006
    Jul 14, 2012
    20
    yes yes.. thanks..
  6. Whyregister
    Sep 12, 2012
    20
    I'm sure you can think of many ways to address that...how about some thing magnetically activated like you can find in simple house alarms?
  7. regal006
    Jul 14, 2012
    20
    so i used microswitch to know the position of the elevator.
    my question is, how to know if i press a button on other floor , the elevator will go up or down,
  8. regal006
    Jul 14, 2012
    20
    so this is what i just made
    0001 - 1F
    0010 - 2F
    0100 - 3F
    1000 - 4F
    i have 10 switches. 4 inside the elevator, switch in 1st floor for people who wants to go up, 2 in 2F to go up or down, 2 in 3F to go up and down, 1 in 4F to go down.
    0001 first floor all switches will make the motor to go up ( Clockwise)
    0010 2nd 1st switch inside the elevator will make it go down, 1st floor
    switch will make it go down too, others will
    make it go up.
    0100 3rd 4th switch inside will make it go up. 4th floor switch will make
    make it go up, other switch will go down.
    1000 4th all switches will make the motor to go down ( counter CW)
  9. regal006
    Jul 14, 2012
    20
    0001 - 1F
    0010 - 2F
    0100 - 3F
    1000 - 4F
    make it go up.
    is this ok? if i use this, i will use a lot of OR gates and AND gates,
    is there any methos to do this?
