i am doing a project based on 16f84a,and it is a timer project
and i have some difficulties which i am trying to overcome problems are
*i want to use a single switch (input)
*mcu should be at rest before switch is pressed and start as switch is pressed
*and while mcu is working if the same switch is pressed it should be paused and should run if the switch is repressed
i am trying to do the project in mikrobasic pls help me
