Need help in optcoupler
Discussion in 'Homework Help' started by mesolg, Mar 19, 2011.
  1. mesolg
    Mar 19, 2011
    Hello every one.....
    i got a shaft encoder and the optcoupler gives an output of 2.4 volts on two terminals (the voltage difference between this two terminals is 2.4) so i need to supply this signal to AVR Microcontroller, so my question is how to supply this signal to the avr in one pin? and how to amplify it to 5 volts ? just to make the avr able to recognize it.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What is the part number of your optocoupler?
    hgmjr
  3. mesolg
    Mar 19, 2011
    It is Sharp ia35r
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Post your schematic showing how you have connected up your optocoupler.
    hgmjr
