Need help in Logic gates ckt
Discussion in 'Homework Help' started by Smoor - Oman, Mar 19, 2009.
  1. Smoor - Oman
    Mar 19, 2009
    5
    Hello everyone...
    I will really appreciate it if someone will just help me with this part of my assignment of designing an IC using CMOS sub-system...
    The question is:
    The Logic combination below, I want it to be designed ONLY by 2-Input NAND gates? or Using 2-Input NOR gates!
    Thanks to everyone...
  2. mik3
    Feb 4, 2008
    4,846
    63
    First, don't expect from someone to make the whole circuit fir you.
    Start with the first term, B'C'D', and make it by using NAND gates. Actually, the first term is a AND gate with NOT gates on its inputs. Make it this with NANDs.
    Then make the same with the second term and so on. Finally, OR all the previous circuits together.
  3. Smoor - Oman
    Mar 19, 2009
    5
    Hello... As I said all the Gates should be NAND or NOR gates only!
    Thanks for replying, but seiously this is not all my circuit! My desired circuit is to fabricate this combination in CMOS using MicroWind2...
    So still I will appreciate it if someone will come up and help me in that...
  4. hitmen
    Sep 21, 2008
    159
    When you encounter an OR , convert into a NAND gate with circles drawn at the input.
  5. Smoor - Oman
    Mar 19, 2009
    5
    Can someone help me with making the ckt [​IMG]
    With 2-NAND gates only?
    Thanks... I need this ckt so I can start with the CMOS dsign
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Try drawing the circuit as a start, then work from there.
    You will find we are willing to help, to give hints or to show where you went wrong, but as a rule of thumb no one answers the questions outright, otherwise how will you learn?
    Show me a logic schematic, and I'll show you how to start.
  7. Smoor - Oman
    Mar 19, 2009
    5
    Thanks for the help man... This is where I reached and got stuck...
  8. Smoor - Oman
    Mar 19, 2009
    5
    Ok Mr. Bill, Could you please check if am going right in the image I attached?
  9. vvkannan
    Aug 9, 2008
    138
    11
    Hello Smoor - Oman,
    Draw the circuit with noremal gates
    Now adding two inverters to AND makes no difference right? .Now replace the AND and first inverter by NAND and represent the second NOT as you have done .
    Whenever you encounter an OR gate ,add two inverters at the inputs of OR gate.
    Remember one NOT added with OR gives you NAND and replace the another NOT by NAND
    example:
    say you want to represent x+y by NAND gate
    add two inverters in x input and two inverters in y input before it is applied to OR.
    Now by our replacement we have x' and y' as inputs for the NAND gate(second NOT added with OR)
    so the output is (x' y')' = x'' + y'' = x + y (by demorgan's law) .This is what we wanted
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, here is the Boolean equivalent.
    And here are the tools you use to change it...
    If you're wondering how I drew these check my blog out, especially my introduction.
