Need help in Identifying an IC
SgtWookie
Joined Jul 17, 2007
22,230
Have a look at this datasheet:
http://www.nve.com/Downloads/il600a.pdf
and this one:
http://www.nve.com/Downloads/il600.pdf
See if the pinouts/signals match what you're seeing.
Digikey stocks these A versions:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=390-1084-5-ND
and these non-A versions:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=390-1082-5-ND
These are just the first parts I'd found on Digikey's site that matched with the *611* and the 8-TSSOP/8-MSOP package.
There are plenty more.
Click on this Digikey search: http://search.digikey.com/scripts/D...earch_go&lang=en&site=us&keywords=611&x=0&y=0
...and then scroll down to Isolators; select one of the 3 links that will appear under that heading.
Narrow your search to 8-pin surface mount type packages, then look through the list to see what all matches the signals you're seeing AND what your parts are connected to.
inistec
Joined Oct 23, 2008
That looks Really close to what I am looking for. It appears that the pin-out is the same. I believe it is close enough to try it. I will order some, and post a reply after I test it.
Thanks for the quick reply.
Thadd
SgtWookie
Joined Jul 17, 2007
22,230
That does look like a prime candidate; the markings on your part seem to match the datasheets' marking specifications as well.
Glad that helped you find something so similar. It's pretty tough to find an exact match for a SMD remotely when I don't have all of the information about the original part.
