need help in engineering process
Discussion in 'Homework Help' started by kawai, Sep 21, 2006.
  1. kawai
    Sep 21, 2006
    I currently assigned to do a oral presentation about enginnering process..
    It is required to present a engineering process of a electronic devices..
    for example a digicam..
    I need to explain from the raw material of making a digicam to the end product..
    it is not neccessary to explain how the internal components work..
    it jus have to explain the production process..
    have anyone here got any idea? or relavent website?
    i cant find what topic to do and cant find any website..
  2. hgmjr
    Jan 28, 2005
    9,030
    214
  3. archana
    Sep 22, 2006
    i am measuring the frequency of servo motor which coming out as 3 phase ac signal. i am measuring the frquencu between two phases, on the frquency meter. if i measure it on meter it is showing correctly, but as soon as i connect cro (scope) to it, is getting disturbed and showing any random value. why it so?
    archana
  4. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Make sure you have your scope probe in the x10 position. You might be loading the servo too much.
