NEED HELP IN designing a class A amplifier
Discussion in 'Homework Help' started by kadomori, Mar 20, 2011.
  1. kadomori
    Jan 29, 2011
    6
    hi professors.
    please help me in designing a class A amplifier. i want a power output of 10 watts for 8ohms load.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  3. kadomori
    Jan 29, 2011
    6
    oh. yes . thanks for the link.
    look at this..
    http://www.elizabethtown.kctcs.edu/members/dbell/CH 09.pps
    look at page 9-5 of the powerpoint file . something like this is what i want to obtain .. the cascaded amp. was put together with power amp. do you know why it's need to put them together?
  4. mjhilger
    Member
    Feb 28, 2011
    119
    16
    Q1 is used as a voltage amplifier. It's output impedance in that design is 1K. While the voltage was amplified, it will not drive much of a load. The power stage are set in an emitter follower configuration. It amplifies current but no voltage. In this particular setup, the base current necessary to drive the final output Q3, is more than the output of Q1 can provide. So Q2 is added in conjunction to Q3 in a Darlington setup to amplify the current many times more, lookup Darlington for more info. The beta of the Q3 transistor is increased
    [​IMG]C3 is a DC blocking cap allowing the coupling of the initial voltage amp to the power amp back section.
