Need help in controlling Voltage and Current
plmrguest
Joined Nov 20, 2015
I am trying to control voltage range from 1.5 to 34 using LM338 voltage regulator with 1000u capacitor at the input 430u capacitor at the output with
potentiometer @ the adjustment terminal.
I have 37v and around 5 Amps current at the Vout but when i try to reduce the voltage using potentiometer,resistor 120 ohms burns out. Please suggest me how to control and get constant Voltage & Current.
34,412
You can get constant voltage or constant current, pick one, you can't control both at the same time.
Post the schematic of what you have.
Dodgydave
Joined Jun 22, 2012
11,302
Sounds like your 120 ohm pot is the constant current regulation resistor,better post your circuit for further assistance.
plmrguest
Joined Nov 20, 2015
Here is my schematic for you reference i have both voltage and current , since we can't control both voltage & current
so i need to keep the voltage constant 32V and current should be adjustable.
bertus
Joined Apr 5, 2008
22,276
You can never have a higher voltage on the output of the regulator.
There will be a dropout voltage of 1.5 to almost 3 volts depening on the drawn current:
Bertus
