Need help in Aptitude Question
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
How to solve this i am working in Aptitude ?
The present worth of Rs. 2310 due 2
years hence, the rate of interest being 15% per annum, is:
A.
Rs. 1750
B.
Rs. 1680
C.
Rs. 1840
D.
Rs. 1443.75
DerStrom8
Joined Feb 20, 2011
2,390
Hmm, if you can't figure this out I guess you're not very apt, are you?
It's called an Aptitude test for a reason. You're supposed to do it, not ask other people to do it for you. This is basic math.
WBahn
Joined Mar 31, 2012
30,088
The first step is to explain the problem in terms that can be easily understood. Try doing that. For instance, if given a present value, V, and an interest rate, R, how would you calculate the future value? The question of how often the interest is compounded is vital to being able to solve the problem.
MrAl
Joined Jun 17, 2014
11,496
I think that maybe the real problem/question is because neither of those multiple choice answers is the correct one :)
I used the method they use around this locale, and could not get any of those results.
WBahn
Joined Mar 31, 2012
30,088
You'll slap your forehead when you see the answer.
You are overthinking it -- think how interest calculations were done when you first learned about them in grade school.
MrAl
Joined Jun 17, 2014
11,496
Hi, wow, that's almost too funny. No wonder they did not mention a compounding period.
That's the year the engineer mostly responsible for building the Royal Canal in Languedoc, a 150 mile
canal in Southern France, died. It was a great acheivement for it's time. It was later renamed however, but i wont give out either name until the OP gets the right result or at least tries again.
Glenn Holland
Joined Dec 26, 2014
703
I'm no good in math so I switched from engineering to becoming a lawyer.
I know there are lots of lawyer jokes out there, but they should be posted in the "Jokes" section.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
A train passes a station platform in 36 seconds and a man standing on the platform in 20 seconds. If the speed of the train is 54 km/hr, what is the length of the platform?
In this question train passes in 36sec that ok, what does this mean man standing in 20Sec?
DerStrom8
Joined Feb 20, 2011
2,390
Are you serious???
LOOK AT THE CONTEXT!
WBahn
Joined Mar 31, 2012
30,088
Actually i am increasing my thinking and capturing power of brain.
How? Whatever you are doing there is little evidence it is working.
Anyway which formula to use in this question answer sheet was not there in web.
And if this is how you are supposedly increasing your thinking and capturing the power of your brain, the reason it isn't working becomes pretty obvious. Instead of reasoning out the solution to a problem, you just want someone to tell you which formula, provided by the power of someone else's brain, will do your thinking for you.
Really? If I tell you that it takes 20 seconds for a train to pass by someone standing on the side of a road you have no idea what that means?
