Need help in Analog FSM Machine
Discussion in 'The Projects Forum' started by ahkompany, Mar 29, 2016.
  1. ahkompany
    Mar 28, 2016
    Well my last thread was not so attractive so this is with a new one with the same problem
    I need to create an FSM Machine but only with analog IC.I can use a memory unit in that project.I am thinking using 2 breadboard one with the circuit and the other one will be filled with leds.
    What i am thinking is that i will save 5 names on that memory unit and with the help of switches the led breadboard will turn on.(not the whole board but the point is that led will show those name)
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    Great. Let us know how it turns out.
    Oh, wait, you have questions? Try asking them. Start with what you've done so far.
  3. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Unless this FSM machine can help you to start a thread that makes more sense than the last two, I wouldn't bother.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,701
    1,299
    The industry standard definition of FSM is Fred Smith Meatball. I suggest you google Fred Smith to get his contact information and ask him directly.
    ak
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    AFAIK you can't make an analog FSM. They are about as pure digital as you can get. You might want to study the material a bit more before making preposterous suggestions.
  6. SLK001
    Nov 29, 2011
    852
    243
    Usually a FSM is made with an antenna, a low noise amp, a battery and a meter. What you could be doing with all that memory and names stuff is beyond me.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Say what???
  8. GopherT
    Nov 23, 2012
    6,315
    4,041
    Full spherical mount? Finite state machine. That is the problem when people talk in TLAs.
  9. AnalogKid
    Aug 1, 2013
    4,701
    1,299
    Slk is referring to a field Strength Meter.
  10. AnalogKid
    Aug 1, 2013
    4,701
    1,299
    Actual bumper sticker:
    ESCHEW TLA'S!!!
