Need help in a project
Discussion in 'The Projects Forum' started by Ali Inam, Oct 26, 2011.
  1. Ali Inam
    Aug 7, 2011
    Hi, I am making up a Velocity Counter using a photo diode. I have planned it to be in the following way:
    I will be having two ends, on both of those ends I will be having photo diodes on one side and laser lights falling on the diodes from exactly opposite sides. Now I will make a toy car move, once the toy car intercepts the first light beam, I want my counter to start the time immediately and as soon as it intercepts the other beam, I want it to stop.
    Can anyone guide me please.
    Thanks....!!
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    A microcontroller with the right set of interrupt pins seems ideal. Do you have any one at hand?
  3. wmodavis
    Oct 23, 2010
    737
    150
    Not exactly what you mean by that. I do not think that velocity is something you can count.
    Maybe what you mean is that you want to determine the velocity by measuring the time lapse from start to finish then calculate velocity as V= dist/time. Is that right?
    If so, you need to count time pulses and divide that into the distance between the two sensors.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I think he already knows that. The problem is the implementation.
  5. RiJoRI
    Aug 15, 2007
    536
    26
    I'm not convinced interrupts are needed with so simple a project. Polling the pins should do the trick, probably down to microseconds!
    Of course, using an S-R latch to control a 555's pulses into a counter could also do, tho' binary to decimal might be problematic, so the micro would b e better.
    --Rich
  6. wayneh
    Sep 9, 2010
    12,403
    3,250
    There are many ways to accomplish this, and the choice partly depends on what the OP wants to use for the timing and display of results.
    One way to capture the start and stop would be to use two 555 timers configured as missing pulse detectors. Pulse the light source and throw the trigger when a pulse is missed. This is a simple circuit for DIY. This would generate a signal at each interruption of the two beams. Then you need to measure the time between those two and get the result. Could be as simple as starting and stopping a third timer attached to a counter. Could be as elaborate as a computer-controlled data acquisition device, which would allow calculating velocity and displaying the results graphically or remotely. Just depends what you want.
