Need help in 8086 assembly language
Discussion in 'Homework Help' started by paklah1976, Oct 28, 2010.
  1. paklah1976
    Oct 28, 2010
    Hi all, im a newbie here
    i have homework to be done but i not understand any of the language...
    here are the question
    QUESTION
    Write an 8086 assembly language program that will display from 0 to 9 seconds and loops continuously thereafter. The LED should be lighted ON during the counting. Assuming that a 1 second delay subroutine, ‘D1SEC’ is available and port A is already initialized to be the output port, at address PORTA.
    hope there is someone here can write me the program language...
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Eh....I think you got the wrong idea on how this forum work. The only person here can that write you the program so you! The thing we offer is help or a push in the correct direction. So instead of dreaming that someone will do your homework for you. Why do you not start on your assignment. Then you are stuck you can ask for help. But remember good questions draw good answers
    paklah1976 likes this.
  3. debjit625
    Apr 17, 2010
    790
    186
    Welcome to AAC
    Make it bit more clear...
    Good luck
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That person is you. We can give specific help, but will not do your assignment for you.
    Try starting with making a flow chart.
