Need help identifying SMD component on this SBC
Discussion in 'General Electronics Chat' started by maxman190, Dec 14, 2015.
  1. maxman190
    Dec 14, 2015
    https://www.dropbox.com/s/9pssmriob7prlnz/20151214_180731.jpg?dl=0
    Directly to the right of the 25.000 MHZ oscillator, you can see a noticeable burnt component (resistor I think?).
    It's a Banana Pi M3, I was messing around with my multimeter on the GPIO pins (I was trying to determine if the GPIO pins for 5v and ground were in the same spot as Raspberry Pi, my negative multimeter probe was on pin 2 and my positive probe was on pin 6 and I think I accidentally touched pin 6 with pin 8 or pin 5, then I saw a spark on that now burnt component....) and accidentally shorted it out.... Is it possible to replace that part or it's completely dead?
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    sure you can replace any part..
    To find out the specs on the part visit the banana pi website.. get the schematic and find the component shown attached to the 4th (or 1st) pin of the USB connector..
  3. maxman190
    Dec 14, 2015
    I did try that at first, but I'm a noob at this. They only provided the schematics diagram and not the PCB layout: https://drive.google.com/file/d/0B4PAo2nW2KfnY2dSS1ZzUlpyTDQ/view
    I have zero clues about what it says....
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think your chances of successfully replacing a small component in a tight space are slim to none, assuming you can get a single replacement part and don't have to buy a whole reel.
  5. spinnaker
    Oct 29, 2009
    5,078
    1,179
    And you will be lucky that the resistor is the only thing that is fried.
  6. maxman190
    Dec 14, 2015
    Soooo... I'm guessing it's dead then? I should probably go ahead and cancel my order for soldering equipment and 0603 SMD components.... To be honest, kind of relieved because those stuff costed 80+ and the SBC was ~70...
  7. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    Great discussion. I was not aware about the banana pi. Thanks for sharing this.
  8. maxman190
    Dec 14, 2015
    Yeah, I suggest you do what I didn't..... Research on it first. It's just been awful trying to use the M3....
