Need help identifying component
Discussion in 'General Electronics Chat' started by 2electrified, Oct 12, 2013.
  1. 2electrified
    Sep 5, 2011
    30
    Hello Everybody,
    I need help identifying a component that needs replacing. On the PCB board it was labeled U3 - does this mean its an IC chip? The part is being replaced on another circuit. The top of it had popped.
    I tried searching 818 and 815y without any luck.
    I included a picture. Any help would be greatly appreciated.
    Lisa
  2. sheldons
    Oct 26, 2011
    616
    101
    It looks like an opto isolator...........
  3. 2electrified
    Sep 5, 2011
    30
    Thank you. I was doing further research and I did finally come up with parts pointing towards opto isolator.
    Are you familiar with opto isolator? Reason for me asking is, I am noticing on some specs - input type is either AC or DC. Is the input type sensitive - meaning, The circuit I am working has 3 opto isolators - 2 are labeled 815Y and one is labeled 8141, and from my research 8141 shows input type AC. What happens if an AC type is in a DC circuit, does that hurt the circuit or visa vera? I am trying to match the current number 815Y and I don't wanna put a wrong part in. And wondering if I should swipe out 8141 and put 815Y in there - since the circuits runs in DC.
    What specs are important to pay attention to opto isolator?
    Lisa
  4. praondevou
    Jul 9, 2011
    2,936
    489
  5. 2electrified
    Sep 5, 2011
    30
    @praondevou - thanks for the info. I will read up on the links you have listed here.
