If you can not find the schematic, it's time for some reverse engineering, drawing the schematic yourself. First find the power supply traces then see where the source, gate and drain go to and check those circuits. If the transistor had a short circuit between drain and gate, the driver circuit may be defective.
Don't worry if you end up talking to yourself, it's perfectly normal with a double sided or multilayer board.
Timescope
Timescope
