need help identify tx and rx pins on cell phone data cable
Discussion in 'General Electronics Chat' started by avichoen, Apr 4, 2009.
  1. avichoen
    Apr 1, 2009
    6
  2. avichoen
    Apr 1, 2009
    6
    Please..
    Can somebody help me to identify where is tx and rx pins on the cell phone connector?
  3. avichoen
    Apr 1, 2009
    6
    someone?..............
  4. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    You links give my computer a warning and it tells me that it is a dangerous website. If your cable is a standard rs232 cable then the pinout can be found at this link.
    http://www.lammertbies.nl/comm/cable/RS-232.html#pins
    A continuity check on a multimeter should help identify the pins on the cell phone connector.
  5. avichoen
    Apr 1, 2009
    6
    Thank you for your reply.
    My links to the data cable photos are not in a dangerous website at all, my photos hosted on http://www.hotlinkfiles.com/faqs website, it's a free file host website and it's free from security threats.
    I'm using the latest kaspersky internet security firewall and antivirus and it doesn't detect any threats on this website. I also googled and didn't found any bad about it.
    Anyhow.. I checked with multimeter the connectivity from the connector pins to the data cable pcb but still doesn't know which is tx and rx.
    You can see all the details in my photos.
    I'll appreciate any help.
  6. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Do you have a 9 pin, or 25 pin, connector on one end, as pictured in the link I showed above?
  7. avichoen
    Apr 1, 2009
    6
    I have 9 pins connector on one end, pcb board in the midle and 18 pins on the cellphone connector.
    Do you want that I upload those photos to another photo host website?
  8. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Did you look at the link I showed in #4? That is the standard rs232 pinout for the 9 pin computer connection. It shows receive pin 2 and transmit pin 3.
    One side of the rs232 connectors is sometimes marked as to which pin is which in small letters. Look at the 9 pin connector and at the computer connection. I can not find any around my desk here, my computer is all usb.
  9. avichoen
    Apr 1, 2009
    6
    Ok.. I looked at your link but it doesn't help much. I need to identify the rx and tx pins on the 18 pins connector that goes to cellphone, not the tx/rx pins that goes to pc with rs232 9 pins connector.
    This is a "sky im-3000" cellphone data cable for transferring files between pc and cellphone and it has a pcb board between the 9 pin rs232 connector and 18 pin cellphone connector.
  10. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    page 13 of your datasheet shows logic level inputs and outputs for max3237.
    Follow tx and rx from the db9 connector to the chip and then use the chip diagram to find the logic level pins that are used. Follow those to the 18 pin connector.
