Thanks,By the looks of your schematic you should go with the 3 lead grounded cap, it's basically the same setup as a cap that you can buy for an automotive ignition coil to reduce noise on you car radio.
Actually they ARE carbon discs. This machine is 30 years old and when I opened the white thingy inside this is exactly what I saw. Cheers Rifaacarbon disks???
what planet are you from Rifaa?
all modern day sewing machines use resistance wire wound foot pedals.
Did I miss something?
The link does not work sitran. I will tell you later about surges, right now don't have too much on my hand, I just review the post as I get few min's to spare.
