need help identifing diode
Discussion in 'Electronics Resources' started by cocobolo95, Mar 13, 2016.
  1. cocobolo95
    Mar 10, 2016
    21
    I have a broken Hypertherm max 20 from 1994. I have determined the problem lies in the chopper board assembly which is no longer available. So I must rebuild the one I have. Most of the components are available. But these 2 large diodes I can find no info on them.
    Not having a schematic that shows the chopper, I don't know what kind of diodes these are or their function. The 2 diodes are the same, a TO-3 case with either 2 common anodes or 2 common cathodes. Made by I R markings 1RF350
    8P3M
    9343G
    Can anyone help me with the ID of these diodes. Data sheet would be great. Since they are probably obsolete, a similar replacement diode if you know of one. And is it a common anode or cathode. Thanks in advance for reading and hopefully helping.
    Have a pic of the diode with markings.
      File size:
      725 KB
      14
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    The IRF350 is a high voltage mosfet.
    Have a look in the attached datasheet.
    Bertus
  3. cocobolo95
    Mar 10, 2016
    21
    Thanks for the quick reply. Do you know if the 1RF350 is still available. And from whom.
    Being new here, how do I get to the user CP to edit my details.
    Also, would anybody happen to have a complete schematic for the Hypertherm max 20 plasma cutter. And a service manual would help.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  5. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    I know Digikey stock them, but I am not sure about the old T204 case style, as a last resort you could get the T220 and heat sink it.
    Max.
  6. cocobolo95
    Mar 10, 2016
    21
    Heat sinking is no problem. The max 20 has a massive heat sink for the 1RF350's to sit on.
    Thanks for the ebay results. Will definitely buy the originals and not the Chinese made ones. I hear horror stories about plasma cutters using the Chinese made MOSFET.
  7. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    Here is one manual.
    Max.
    • abc.pdf
      File size:
      4.3 MB
      6
  8. cocobolo95
    Mar 10, 2016
    21
    Thanks for the manual. Unfortunately it only has a partial schematic in it that leaves chopper out.
  9. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    Appears to just show the chopper as a square block.
    Probably a PWM circuit, might be possible to just reverse engineer it if not much to it?
    Max.
  10. cocobolo95
    Mar 10, 2016
    21
    Reverse engineering is beyond my pay grade. But the chopper board is made up of common components that are easily sourced. Now that I know that 1RF350 is a MOSFET and sources have been provided to me, I can rebuild the chopper.
    It would have been nice to have the complete schematic so I could study the working of the circuit.
  11. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    You can change your personal details by the drop down on your top right signature.
    It pays to show your country of origin it makes help a little easier.
    max.
  12. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    Not sure if you found it, but I came across this.
    To Test the chopper you must first find and test the soft start resistor on the rear panel. If it is blown You will have to replace both the resistor and the relay that bypasses it. (3CR). cooling fan must run. Next find the small relay in a plastic box and see if it moves with and trigger pull. The large one with the magnet should pull in also.
    The small one turns the chopper on. The large one applies power to the torch. Gas valve should open just after both relays close. We have to have power in the torch before the gas is turned on in order to make a spark and get the plasma working. Look the pc board over real close. looking for any thing burnt. The pc board is part of the chopper assembly and is not available separately. The large capacitor should have around 244 vdc on it.
    Other than damaged torches. The common problems are the soft start resistor and relay. Also the chopper on relay waring out. appears to move but does not make contact.
    Hypertherm has just announced that these plasma's are at end of life. Which means they are no longer going to stock parts for them. May be available by special order, if it is still made.
    Max.
  13. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    That's how I remember it - there's almost certainly a plastic package device that will fit the metal TO3 mounting holes.
  14. cocobolo95
    Mar 10, 2016
    21
    Thanks for the good info. I have already checked with hypertherm and chopper assembly is no longer available. The 3 relays are still available. It's funny that hypertherm tech didn't know what was on the chopper board or the 2 Mosfet.
    Went through troubleshooting with the hypertherm tech. All the relays and soft start resistor checked out as being good. The 4res resistors for piolet arc also tested as good. Which left me with the chopper circuit board and the 2 1RF350 MOSFET on heat sink.
    Seeing that unit is 22 years old and has never been repaired, rebuilding the chopper board should get the old girl back up and running again.
  15. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    When looking to buy the part make sure you use the letter "I", as in igloo, and not the number "1" as the first character of the part number.
  16. cocobolo95
    Mar 10, 2016
    21
    Good point, thought fist symbol was a "1" that's why I thought the semiconductor was a diode. Keep the info coming. I am only a hobbyist who is winging it through the troubleshooting process.
  17. MaxHeadRoom
    Jul 18, 2013
    10,826
    2,495
    IR, as in International Rectifier, there are at least 3 other manuf of these.
    Max.
  18. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  19. ian field
    Oct 27, 2012
    4,447
    791
    The modern part may well have an "IRFP" prefix.
    The original part number isn't impossible to track down, so datasheet specifications can be matched to an equal or better modern part - you don't have to only buy IR parts, but if there's a pair of them, they should be replaced as a pair.
  20. cocobolo95
    Mar 10, 2016
    21
    Going to order 2 pair of these from the link bertus supplied to ebay. Decided to get 2 extra, just in case.
