need help here for sample question
Discussion in 'Homework Help' started by saif-aljanahi, Mar 21, 2016.
  1. saif-aljanahi
    Feb 26, 2016
    18
    hello , how are you all , i hope fine
    i have just two question about voltage doubler
    1-what are applictions of voltage doubler circuit
    2-how we can make a voltage doubler circuit work more Efficiently
    and thank you a lot for helping me
  2. WBahn
    Mar 31, 2012
    18,093
    4,918
    Well, let's see, you might use a voltage doubler in applications where you wanted/needed to double the voltage.
    The second question is all but meaningless. If you start with a voltage doubler circuit that is very inefficient, then there would likely be lots of ways to make it more efficient. But if you start with one that is as efficient as a voltage doubler circuit can be, given present state of the art, then there is no known way to make it more efficient.
  3. saif-aljanahi
    Feb 26, 2016
    18
    thank you very much , WBahn , you helped me a lot with this question and others ..
  4. saif-aljanahi
    Feb 26, 2016
    18
    i asked my teacher about how we make this circuit more efficiently and he said by add an emitter common transistor or collector to Amp the current , is this correct ?
  5. WBahn
    Mar 31, 2012
    18,093
    4,918
    What circuit????
    You haven't given a circuit for consideration!
    There a MANY different types of voltage doubler circuits. We are NOT mind readers!!
  6. saif-aljanahi
    Feb 26, 2016
    18
    im sorry , that's true there many circuit of VD
    my circuit is :
  7. WBahn
    Mar 31, 2012
    18,093
    4,918
    If you have a transformer, why not just double the turns on the secondary and be done with it. Get rid of the doubler altogether and just use the diodes to make a full wave rectifier.
