Need Help! generate tone using C
Discussion in 'Programmer's Corner' started by nearownkira, Mar 26, 2008.
  1. nearownkira
    Feb 19, 2008
    20
    Is there a way that u can write the code in C to generate tone such , A or G tone like in assembly?I know how to write the delay function, but I did not see any equivalent code in writing to the timer register.
  2. mgalvez
    Mar 27, 2008
    First of all, sound is typically platform specific. What's the platform and I'll see what I can muster up for ya.
  3. mgalvez
    Mar 27, 2008
    // PC Running MS-DOS, Borland Turbo C++
    #include <stdio.h>
    void sound(int frequency);
    void main(void) {
    int myFrequency;
    myFrequency = 2000; // Sample frequency to make this listing work...
    sound(myFrequency); // Whatever the frequency for Middle C is...
    void sound(int frequency) {
    asm {
    mov al, 182; out 43h, al; mov ax, frequency
    out 42h, al; mov al, ah; out 42h, al; in al, 61h
    or al, 2; out 61h, al; mov bx, 25
    task1:
    mov cx, 65535
    task2:
    dec cx; jne task2; dec bx; jne task1; in al, 61h
    and al, 252; out 61h, al
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Using the code & /code tags helps a great deal when posting program listings - it preserves the original formatting.
    Code ( (Unknown Language)):
    1.
    2. // PC Running MS-DOS, Borland Turbo C++
    3. #include <stdio.h>
    4. void sound(int frequency);
    5. void main(void) {
    6.    int myFrequency;
    7.    myFrequency = 2000; // Sample frequency to make this listing work...
    8.    sound(myFrequency); // Whatever the frequency for Middle C is...
    9. }
    10. void sound(int frequency) {
    11.    asm {
    12.       mov al, 182; out 43h, al; mov ax,  frequency
    13.       out 42h, al; mov al,  ah; out 42h, al; in al, 61h
    14.       or  al,   2; out 61h, al; mov bx, 25
    15. task1:
    16.       mov cx, 65535
    17. task2:
    18.       dec cx; jne task2; dec bx; jne task1; in al, 61h
    19.       and al, 252; out 61h, al
    20.    }
    21. }
    22.
    Middle C=261.63 Hz, 262 is close.
    Middle A=440 Hz exactly.
    Middle G=392 Hz exactly.
    See: http://www.phy.mtu.edu/~suits/notefreqs.html
