I've got pic code working to a stage where I need to take it to the next level.
Basically the code is for driving 3 stepper motors. Currently Just steps them in one direction.
So if you send the number 1 through the PC serial port, Stepper 1 steps. number 2 steps stepper 2 and 3 steps stepper 3.
What I would like to do now is send a message to the pic.
i.e. 1 500 5 So this translates into Stepper 1, 500 steps at 5ms interval, 2 5 1 This translates into Stepper 2, 5 steps, 1ms interval
My current code....
My current code....
Rich (BB code):
LIST P=16F628, R=DEC ; Use the PIC16F628 and decimal system
#include "P16F628.INC" ; Include header file
__config _INTRC_OSC_NOCLKOUT & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
CBLOCK 0x20 ; Declare variable addresses starting at 0x20
count1
dataL
Check_Temp
ENDC
#DEFINE STEPPER1 PORTB, 0
#DEFINE STEPPER2 PORTB, 3
#DEFINE STEPPER3 PORTB, 4
ORG 0x000 ; Program starts at 0x000
; SET ANALOG/DIGITAL INPUTS PORT A
movlw 7
movwf CMCON ; CMCON=7 set comperators off
; INITIALIZE PORTS
movlw b'00000000' ; set up portA
movwf PORTA
movlw b'00000100' ; RB2(TX)=1 others are 0
movwf PORTB
bsf STATUS,RP0 ; RAM PAGE 1
movlw 0xFF
movwf TRISA ; portA all pins input
movlw b'11100010' ; RB7-RB5 and RB1(RX)=input, others output
movwf TRISB
; SET BAUD RATE TO COMMUNICATE WITH PC
; Boot Baud Rate = 9600, No Parity, 1 Stop Bit
movlw 0x19 ; 0x19=9600 bps (0x0C=19200 bps)
movwf SPBRG
movlw b'00100100' ; brgh = high (2)
movwf TXSTA ; enable Async Transmission, set brgh
bcf STATUS,RP0 ; RAM PAGE 0
movlw b'10010000' ; enable Async Reception
movwf RCSTA
; PROVIDE A SETTLING TIME FOR START UP
clrf dataL
settle decfsz dataL,F
goto settle
movf RCREG,W
movf RCREG,W
movf RCREG,W ; flush receive buffer
; MAIN LOOP
call message ; send intro message
loop call receive ; wait for a char
call Check_Input ; Check to see what type of input it is
goto loop
; RECEIVE CHARACTER FROM RS232 AND STORE IN W
; This routine does not return until a character is received.
receive btfss PIR1,RCIF ; (5) check for received data
goto receive
movf RCREG,W ; save received data in W
return
; SEND CHARACTER IN W VIA RS232 AND WAIT UNTIL FINISHED SENDING
send movwf TXREG ; send data in W
TransWt bsf STATUS,RP0 ; RAM PAGE 1
WtHere btfss TXSTA,TRMT ; (1) transmission is complete if hi
goto WtHere
return
Check_Input movwf Check_Temp ; Put the character received into memory
MOVLW 0x31 ; Is it the number 1? If so call Step1 to drive stepper motor 1 one nudge
SUBWF Check_Temp, w
BTFSC STATUS, Z ; Does it match?
CALL step1 ; Yes
MOVLW 0x32 ; Is it the number 2? If so call step2 to drive stepper motor 2 one nudge
SUBWF Check_Temp, w
CALL step2 ; Yes
MOVLW 0x33 ; Is it the number 3? If so call step3 to drive stepper motor 3 one nudge
SUBWF Check_Temp, w
CALL step2 ; Yes
MOVLW 0x3F ; Is it a question mark? If so call intro message
SUBWF Check_Temp, w
CALL message ; Yes
return
; STEPPER MOTOR STEP CONTROL - ONE (RB0)
step1 BSF STEPPER1 ; STEP the Stepper 1 motor
call Delay ; Call Delay so there is enough time for the stepper motor controller to see a high
BCF STEPPER1 ; Turn off the output ready for the next command.
Call Delay
return
step2 BSF STEPPER2 ; STEP the Stepper 2 motor
BCF STEPPER2 ; Turn off the output ready for the next command.
call Delay
return
step3 BSF STEPPER3 ; STEP the Stepper 2 motor
BCF STEPPER3 ; Turn off the output ready for the next command.
call Delay ; Call Delay so there is enough LOW period before going to the next cycle.
return
; MESSAGE
message movlw 'T'
call send
movlw 'i'
call send
movlw 'm'
call send
movlw 'e'
call send
movlw ' '
call send
movlw 'L'
call send
movlw 'a'
call send
movlw 'p'
call send
movlw 's'
call send
movlw 'e'
call send
movlw ' '
call send
movlw 'C'
call send
movlw 'o'
call send
movlw 'n'
call send
movlw 't'
call send
movlw 'r'
call send
movlw 'o'
call send
movlw 'l'
call send
movlw 'l'
call send
movlw 'e'
call send
movlw 'r'
call send
movlw 0x0D ; CR
call send
movlw 0x0A ; LF
call send
return
; ====================== DELAY ROUTINES ===================================
Delay
movlw .1
movwf count1
dloop1 decfsz count1,f
goto dloop1
goto $+1
retlw 0x00
END
