Need help for Square Signal Comparator
Discussion in 'General Electronics Chat' started by Mr.Dido, Nov 18, 2007.
  1. Mr.Dido
    Nov 18, 2007
    5
    Dear all,
    Hi. i have small problem. i have a switch give me output as square signal 2.7 V(p-p) when its OFF. when its ON give square signal 3.9 v(p-p). My request is to discard the small signal 2.7 V(p-p) from comparator output by using DC voltage references.
    please for all who can help me, send a circuit design.
    regards
  2. studiot
    Nov 9, 2007
    5,005
    515
    About your simplest solution would be a 3v6 zener in series with the switch output.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Let me see if I understand your question.
    You want to monitor a signal controlled by a switch. When the switch is OFF the signal you want to monitor is 2.7v p-p. When the switch is ON the same signal changes to 3.6v p-p.
    Does the 2.7V p-p signal swing between 0V and 2.7V? If not, what two voltages does it swing between? The same information on the 3.6V p-p signal would be inportant to know. Also are both signals the same frequency?
    It is unclear from you description whether you want to block the 2.7V p-p signal and pass the 3.6V p-p only or just generate a logic signal that indicates that the signal is 2.7V p-p with a low and then 3.6V p-p with a high.
    hgmjr
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A voltage comparator might do. Put a voltage above 2.7 on one terminal, and the output won't change until the higher 3.6 volt signal is present.
  5. Mr.Dido
    Nov 18, 2007
    5
    Dear
    the both signal swing between Vp-p to zero and frequency of them not equal as i remember and all what i want "block the 2.7V p-p signal and pass the 3.6V p-p only" by using DC voltage referance
    regards
  6. Mr.Dido
    Nov 18, 2007
    5
    Dear
    thnx for ur information
    regards
  7. Mr.Dido
    Nov 18, 2007
    5
    Dear
    regards
  8. Mr.Dido
    Nov 18, 2007
    5
    Only for Refresh
