1: #include <pic.h>
2:
3: int i, j; // Array Pointers
4:
5: int ADCState = 0; // Keep Track of ADC Operation
6: int ADCValue = 0; // Initialize to zero on declaration
7:
8: int Dlay = 63; // LED Time on Delay Variable
9:
10: //Pattern to display on LEDs
11: const char PORTAValue[8] =
12: { 0b010000, 0b100000, 0b010000, 0b000100, 0b100000, 0b000100,
13: 0b000100, 0b000010 };
14: // Force off Array
15: const char NOTPORTA[8] = { 0, 0, 0, 0, 0, 0, 0, 0 };
16:
17: // IO Ports, 1 = Input, 0 = Output
18: const char TRISAValue[8] =
19: { 0b001111, 0b001111, 0b101011, 0b101011, 0b011011, 0b011011,
20: 0b111001, 0b111001 };
21:
22: main ()
23: {
24: PORTA = 0;
25: ANSEL = 1 // Just RA0 is an Analog Input
26: MCON0 = 7; // Turn off Comparators
27:
28: ADCON0 = 0b00000001; // Turn on the ADC
29: // Bit 7 - Left Justified Sample
30: // Bit 6 - Use VDD
31: // Bit 4:2 - Channel 0
32: // Bit 1 - Do not Start
33: // Bit 0 - Turn on ADC
34: ADCON1 = 0b00010000; // Clock ADC from FOSC/8
35:
36: while (1 == 1) // Loop Forever
37: {
38: for (i = 0; i < 8; i++)
39: { // Loop through Each of the 8 LEDS
40: for (j = 0; j < Dlay; j++); // Display "On" Delay Loop
41: if ((ADCValue & (1 << i)) == 0)
42: PORTA = NOTPORTA[i]; // Change lit LEDs
43: else
44: PORTA = PORTAValue[i];
45: TRISA = TRISAValue[i];
46: }
47: switch (ADCState) // ADC State Machine
48: {
49: case 0: // Finished, Start Next Sample
50: GODONE = 1;
51: ADCState++;
52: break;
53: case 1: // Wait for ADC to complete
54: if (!GODONE)
55: ADCState++; // Sample Finished
56: break;
57: case 2: // Save Sample Value in "ADCValue"
58: ADCValue = ADRESH;
59: ADCState = 0;
60: break;
61: }
62: }
63: }
Thread starter | Similar threads | Forum | Replies | Date |
D | 555 Astable timer integration to MCU pic18f4550 need help.. | Microcontrollers | 33 | |
R | need help in pic18f4550 programming | Microcontrollers | 2 | |
Y | PIC18F4550 timer programming>> need help! | Microcontrollers | 10 | |
C | need help for adc programming using PIC18F4550 | Programming & Languages | 4 | |
C | need help for PIC18F4550 | Programming & Languages | 0 |
by Jake Hertz
by Jake Hertz
by Robert Keim
by Aaron Carman
