Need help for lcd
Discussion in 'The Projects Forum' started by adriano08, Jul 7, 2010.
  1. adriano08
    Apr 25, 2010
    33
    Hi.
    I programmed a 16x2 lcd to my microcontroller and is working while running under MPLAB.
    Problem is:
    How do I connect to a breadboard circuit so that when the circuit output trigger a signal, it will run the lcd program automatically(without software like MPLAB).
    Thank you.
  2. retched
    Dec 5, 2009
    5,201
    313
    can you post a screen shot of your circuit or a schematic? Preferably in PNG or PDF format?
  3. adriano08
    Apr 25, 2010
    33
    Hi there.
    Actually I want it to display lcd message from a receiver circuit using a decoder.
    Output from the decoder.
    How should I make it to display message when a receiver received a signal from transmitter?
    Any idea?
  4. BMorse
    Sep 26, 2009
    2,675
    234
    You will have to provide more information to be able to get help, you need to post a circuit schematic of what you have accomplished, and data sheets to the decoders and LCD would also be helpful...
    B. Morse
