Need help for battery charging circuit
Discussion in 'General Electronics Chat' started by sudharshan.panduranga, Aug 7, 2008.
  1. sudharshan.panduranga
    Thread Starter Active Member
    Apr 10, 2008
    61
    Hi....
    Can any one give idea for Battery charging circuit to meet following requirement.
    I am using 3.6v/600mAH rechargeable battery. This will charge from +5V DC supply.
    1. When the Battery is fully discharged, the +5v supply should provide 23mA current to charge the battery till it reaches +3V.
    2. After It reaches +3V the battery should consume required current.
    srisuresh likes this.
  2. iamspook
    Member
    Aug 6, 2008
    27
    What it meant by 'consume required current'? Is this battery running a circuit while being charged? or is it a stand-alone charger?
  3. nanovate
    Distinguished Member
    May 7, 2007
    665
    need to know what kind of battery also...
    Look at bq2057 from TI for lithium-ion batteries
    why 23mA?
  4. sudharshan.panduranga
    Apr 10, 2008
    61
    The current limiting circuit is required till it charges to 3V.
    After it reaches 3V, Current limiting circuit should be inactive.
    Direct +5V should charge the Battery after it reaches +3V.
  5. sudharshan.panduranga
    Apr 10, 2008
    61
    My project is Power supply generation module to get +15VDC from Line 3 phase CTs. I have derived +5V, +8V, +12V from the +15V constant voltage.
    I should get +15VDC constant voltage when Primary 3 phase Line current reaches 1A.
    *If Battery is connected to +5V directly, it can't get +15V at 1A current bcause of Battery current consumption.
    * Thiswill work if i adjust the battery current to 23mA around value.
  6. srisuresh
    Nov 29, 2011
    Hello sir..
    I need a battery charging circuit diagram.
    Actually me planned to implement by using this circuit but some components are not available.
    So please tell a circuit diagram for charging 9V battery.
    THANK YOU
