Need help finding schematics
Discussion in 'General Electronics Chat' started by intheshed, Sep 15, 2010.
  1. intheshed
    Sep 15, 2010
    Hi, Im looking for schematics for a Chicago electric - 2000 Watt / 4000 Watt
    Peak Power inverter part number 95596 from harbor frieght. i did search there
    site with no luck, and i could use it asap. Or if you some advice about how I
    should go about repairing it, that would be great. It simply will not power
    on. TY in advance for your help :)
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Chances are you'll never find one. Most all HF stuff like that is contract manufactured by many different firms in China. If one is ever returned to them they simply replace it and the defective stuff is tested, if it has failed they simply chunk it.
    This doesn't mean that common sense can't help you to repair what you have. Open it up and start looking for the obvious. Ohm out the output FETs, look at the electrolytics etc.
